QUOTE (Koolguyson @ Jun 19 2009, 08:06 PM)
index.php?act=findpost&pid=47317It is very likely that a piston will hit the head with a squish that tight. Remember that rods always stretch a little under load and parts expand with heat.
I agree and also the larger bore pistons have more movement out at the edges of the exhaust and intake sides under normal operating conditions(piston Rock), if you are at .040 on the sides you may be at .020 or closer, front or rear.. no one would set a 78 bore DM under .040 or at it either ...the books dont have a "magic number" they just give "minimum clearances" and most of the info in most of these books are a bit out dated.
I have seen plenty of motors eat themselves alive with deto, from to much squish velocity
