21 - 40 of 61 Posts
QUOTE (outthahole @ Aug 28 2009, 05:07 AM) index.php?act=findpost&pid=54634wow! that's some awesome #'s for just a 3mil crank! who did ur port work,and is that w/+1 valves?also what cams,piston,and compression?carb size?alky? if you don't mind me asking..i completely understand if ya wanna keep ur build a secret to..i was just curious..nice #'s! Thanks,Marcus
also what gearing do you run,and is that the same gearing you ran on the dyno?
QUOTE (2slo4u @ Aug 28 2009, 05:15 AM) index.php?act=findpost&pid=54636my honda had no problem pulling in 5th gear. it made within 1hp of peak for just a shade over 3000 rpm.
3000 rpm? What rpm do you start your dyno run at?
QUOTE (2slo4u @ Aug 28 2009, 09:04 PM) index.php?act=findpost&pid=54724he started the pull @ 5500. it stayed in that range from 6700 to the rev limiter @ 9800
ok..that's about the same rpm we start our pull's too..it's making good power,any track times yet?i have a buddy w/a 06 w/same power as ur's and he was curious of what they should run.
QUOTE (2slo4u @ Aug 29 2009, 08:35 AM) index.php?act=findpost&pid=54770it ran 4.8s i sold it over the winter.
it ran high 4.9s low 5.0's unported with 13.5 je 3 ring, and hc 2 cam on a +6 arm with no bar on mini desert trac's
that's deff impressive!..nice time's..shoulda held on to that bad boy!
ahh its ok, the ds i have now is bone stock motor, bolt on bike and has ran a best of 5.10 on motor 1.778 60ft @ 59mph. on the 15 shot before i did some tuning it was picking up 4 tenths. with the 20 pill it should run consistant 4.7s.
QUOTE (2slo4u @ Aug 29 2009, 08:49 PM) index.php?act=findpost&pid=54825ahh its ok, the ds i have now is bone stock motor, bolt on bike and has ran a best of 5.10 on motor 1.778 60ft @ 59mph. on the 15 shot before i did some tuning it was picking up 4 tenths. with the 20 pill it should run consistant 4.7s.
yeah,ya gotta love nitrous..it's a great equalizer..
ride the banshee's on the track yfz is a hill shooter
what kinda numbers would it make off the bottle? and, by the way banshee is king of the hill...lol
421cub 95hp all motor on gas. yfz's are for jumping! lol... just kiding bro.. i want a 450..
QUOTE (T-Rex @ Aug 5 2009, 06:02 PM) index.php?act=findpost&pid=5235262rwhp/39tq 470YFZ on Alky.wow! that's some awesome #'s for just a 3mil crank! who did ur port work,and is that w/+1 valves?also what cams,piston,and compression?carb size?alky? if you don't mind me asking..i completely understand if ya wanna keep ur build a secret to..i was just curious..nice #'s! Thanks,Marcus
Sorry it me so long to respond its a WR 450 crank 97mm bore, 14:1 cp piston, 45mm HSR Carb, and running VP M5 fuel, I ported my own cylinder head stock valves and springs, web 923 cams. No stroker in this one but my new 501 will be a stroker 98mm bore.
2004 DS 770
red 05 plastics
red 05 seat
stock stearing stem
stock handle bars
ODP A-arms
custom +7 swing arm
not quite 3 quarts of oil
a little bit of oklahoma sand, and Genoa sand, and Off Road Ranch sand/dirt
ron wood front 16t sprocket
sprocket specialist 40t rear sprocket
530 chain lubed with wal mart chain lube
71 horsies
61 ft lbs
But thats only because it was like 100% humidity, and like 140 degrees outside, and dyno shop had no ventilation, and the dyno tires were like 100 lbs each, and it was slipping the tires on the drum, and slipping the clutch, and the timing was extremely retarded, and the only fuel we had for it was like 180 octane. So with all that considered, it normally would have been like 97 hp and 75 ft lbs, easily.
Predator 6mil big bore 646 cc 72/48 on Q16 Gonna mess with the cam timing, pipe and filter on the dyno.
if you went to mrx01 or mr12 youd see more hp and more overrev.
I have thought of trying MRX01. I have a different exhaust cam on the way that has 4 more degree's duration .020" more lift. That and some degree changes should bring up the rpm at which it makes peak HP. Still need a good Dasa drag pipe to finish it.
21 - 40 of 61 Posts
