400ex drag
3206 Views 6 Replies 2 Participants Last post by  Hondawasaki
Does anyone know what some good cheaper mods are for a 05 400ex for drag racing? Right now i have a hmf slip on exhaust on it and 18" itp holeshots that are pretty much new? Do i want bigger or smaller tires for drag racing?
1 - 7 of 7 Posts
?? are you dirt dragging or asphalt . and do you wish to use it as a daily rider or strict drag racer? the first thing i would do is to get a JET kit and rejet the carb to match the HMF exhaust . simply swapping the part does not add much if any power .
proper carb jetting with the pipe and open air box will add a few ponys .
.. a good dirt drag tire is the 22" 4 snows .... for a 400 ex .... at my old dirt track there was a guy running 5.5's on a mostly stock 400ex with the 4snow tires .
.the type of track you race on will change the ideal tire to run . also all the other variables come in to play like HP, torque ,Center of gravity, rider weight ....( so it is a guessing game)
race rules also apply ... most Real races do not allow Spiked tires but they are awesome for practice time and free play ..
weight reduction will make you quicker . rotating mass weight reduction helps even more as it frees up wasted HP . so if you dont need it . remove it . every ounce counts.
a alloy drag axle will make a big difference .. but cost is expensive . if u shop used ones you can save some $$ ( most are for Yamaha but fit honda style bearing carriers .) so a banshee , blaster ,or warrior drag axle will work . and uses a 400ex sized rear brake ass.) you will need to use banshee rear sprockets and rims . ( templates can be bought on ebay to redrill a new set of holes so your rims will fit both honda and Yamaha .) it is better to have the Yamaha 4/115 pattern hubs vs the honda 4/110 ones because most of the dragers run yamaha . this makes it easier to find used drag tires to buy or borrow . and save lots of cash .
cheap weight reduction can be as simple as removing the shocks and using pieces of pipe with holes drilled in them in place of the shocks . if you don't like the idea of no suspension then Marvin Shaw shocks is the way to go . the more expensive option is fox floats.
lowering the stance of the quad helps also... simply lower and level ... for dirt be sure to leave 3-4" of clearance so it does not bottom out when the track gets muddy or rough.
for light front tires think full buff scat tracks on dirt ... or buy a set of scooter tires and buff them yourself to save cash ( it is smelly and messy) and DWT rims are nice and light ....
a even lighter front end would be using spindle mount rims and removing all the front brake components. ( use caution and make sure you have room to stop using only rear brakes )
Thanks for the info Hondawasaki. I do use it as a daily driver and plan on drag racing it on a dirt track that's about 300 - 400 feet long in a couple weeks if that helps any
In that case just swap the rear shock for peice of steel pipe. And run a pair of 4 snows or maybe a 8paddle hauler tire. .. U could optionally drag cut a pair of knobby tires. Some do checker patterns .. Or straight rows removing every other row of tread.
And practice launching in 2nd gear. Then after the race u can go back to normal in 30 min
Sent from my Z752C using Tapatalk
BTW I have a pair of 8p 20" haulers mounted on DWT rims 4/110 pattern that are no use to me.
Ok thanks Hondawasaki. And running the hmf slip on will have more power if i also re jet it?
A very late response but yes . the slip on plus running with out the air box lid . then rejet for a perfect tune ... with out the rejet it will run a bit lean and hotter than normal. the mild jetting will get the mix back on track and take advantage of the extra air flow.
1 - 7 of 7 Posts
