what length swing arm r you running , what i try to do is run as less paddles ,as i can get away with and still maintain traction . If you run a bar make it at least 6ft long . Keep the tires you have been running and start taking inches from your swing arm ,until it goes on the bar smooth and holds the wheels up at lest 75 ft out or more . Set the bar so that your front wheels float in the air about 6 in from the ground. if the front wheels go much higher than that you are losing time and it will be hard to control .if you go to far in and it starts slamming the bar, try a little less paddle or go back out 1 or 2 in until it goes on the bar smooth at take off. i now its a lot of work but its well worth it, it has always worked for me . your 60ft times and mph should increase all so . win you can do both your et's will drop . you could run a long swing arm and a lot of paddles to make it hook , but your mph will suffer. it takes a good combination of 60ft and mph to make a quick bike . most people want to go to a bigger motor , or just keep tuning on there motor ,because its not running hard .when you know your motor tuned right, leave it alone and start looking at your chases setup and tune it over and over again and leave the motor alone . i just about guarantee you will find et . i just think if people would focus on what they have ,instead of thinking bigger is better and work on the chases as much as they tune their motor ,they wold be surprised at what they could get out of their set up . thats the best lesson my dad passed on to me about the sport of sand drag racing . he did it for 50 years and he beat that into my head ,for the 28 years that i spent with him .
win i go back to the chases set up, over the motor i always find et . he always said its 10% driver 15% motor 75% tuning . I'm not saying you tune your motor to much, or you want a bigger motor, I'm just passing on what was taught to me and has always worked for me . maybe it can help some one else also
