I check my squish clearance on my two stock cylinder dragger.
i check my squish clearance with a tin file.
On my stock stroke one, i'm about 0,47 with standard 18cc and 0,10 base gasket.
On my 4mill one, i'm about 0,67 with 0,10 base gasket. I run cut dome without spacer plate.
I think this big squish hurt my 4 mill engine alot. I have a lot of problem to jetting them, i'm actually at 175 main jet on my keihin 36mm pwk.
I'm at 200 feet elevation. I run vp c12 1/3 with 2/3 premium, with nitrométane
From your experience, it's possible to have problem with a engine with an excessive squish?
thank you
bansheeqc
thank you
bansheeqc
