A machine shop worth their salt should be able to get that chamber cut properly and get your compression up as well.
When you hear cc's, that means volume of the head.
In other words, if you were to put a spark plug in, fill the head with liquid to the very top without spilling over, it would hold that many cc's of liquid. As said, the less cc, the more cranking and static compression.
My advice is get a Chariot or Noss head and have domes cut for your application. They'll need to know what stroke the crank is, bore size (as said, 68mm) and the type of piston you are using (banshee and blaster are the most common types, but the dome angles are different)
PM backcountry on here. I get all my domes from him and have had great success with his work.
