QUOTE (KaosBanshee44 @ Oct 27 2008, 06:34 PM) index.php?act=findpost&pid=14060I'd go with porting if you haven't done that yet.
I live in so cal, , who is the top porter? I shoot the hill, I drag race, not much of a duner.
QUOTE (BBIII @ Oct 27 2008, 06:46 PM) index.php?act=findpost&pid=14061The possabilitys are endless it just depend's on your cash flow and what you are wanting out of it.
What is the biggest bang for the buck?
QUOTE (BBIII @ Oct 27 2008, 10:47 PM) index.php?act=findpost&pid=14066Cub cylinders
if u dont have the $ and need to stay with stock cylns.... look up herr juggs... kev does some nice port work.
QUOTE (BBIII @ Oct 27 2008, 07:47 PM) index.php?act=findpost&pid=14066Cub cylinders
Thank you for the info. It sounds like its time for cubs. I want to be shure b-4 I spend the money, so all the info really helps. Once I put the cubs on, it will need: carbs, different pipes than the toomy t-6s, and an extension for the rear?
QUOTE (kawiking @ Oct 27 2008, 09:30 PM) index.php?act=findpost&pid=14072if u dont have the $ and need to stay with stock cylns.... look up herr juggs... kev does some nice port work.
QUOTE (badassbanshee479 @ Oct 28 2008, 07:41 AM) index.php?act=findpost&pid=14130to make a cub run right you need cpis or shearers 35-39mm carbs lock up, override, longer swinger etc.... well worth it in the end.
Thanks for the info. Thats one badass shee you got. I hope to head in that direction with mine.
New rear tires...I bet your bike would probably feel like a new bike compared to the slicks on there now....
Get your stockers ported. Start there...
Jumping from a bolt on motor to an aftermarket cylinder rocket is a HUGE step up...and these aren't just kick it and ride bikes.
You'll have to learn how to setup and tune your ride...either the right way, or the expensive way.....
thats where id start out.. a nice stock cyln drag port, bigger carbs , about a +6 swing... u could do alky on them. a overide and lock up is a option. not a must .
i went from stock to a cub and realized there was alot !! to settin it up right. u could even get a 4 mil crank for a stock cyln... then ur one step closer when u go to a cub.
talk to some builder... herr juggs is in cali.. i ve used jeff at f.a.s.t.
thers alot of good builders out there.. and this is a great forum to learn and ask ?'s
give Nate at McCoys performance a call. aka "moretorque" on this forum, he's from your neck of the woods and does everything your looking for, from mild to wild mostly wild!!!
