QUOTE (rotax00 @ Sep 12 2008, 08:09 PM) index.php?act=findpost&pid=10651im am buying web 109 cams for my ds just wondering if they dont come with springs or retainers will my stock ones be fine?
Yes, you will need a valve spring kit. I am also going to move this thread to the 4-stroke section.
QUOTE (Koolguyson @ Sep 13 2008, 01:17 PM) index.php?act=findpost&pid=10670Yes, you will need a valve spring kit. I am also going to move this thread to the 4-stroke section.
Thanks
That's right , you will also need to change the piston or your valves will smack the flat stock piston.
QUOTE (REDLINE @ Sep 17 2008, 09:34 PM) index.php?act=findpost&pid=11020Are the crowns thick enough to fly cut some valve reliefs in?
I would be afraid to. The piston is a cast and will be pretty thin, to much heat could break or blow through it. You could get a 11.5 for $260 and be safe and still run pump gas.
QUOTE (THEBOM @ Sep 18 2008, 06:23 AM) index.php?act=findpost&pid=11030I would be afraid to. The piston is a cast and will be pretty thin, to much heat could break or blow through it. You could get a 11.5 for $260 and be safe and still run pump gas.
thanks shes back 2gether and running strong thanks 2 your advise.
1 - 6 of 6 Posts
