QUOTE (dajogejr @ Jul 17 2008, 10:58 AM)
index.php?act=findpost&pid=5653I think I know the answer, but want to double check...
35PWKs can be bored to 39 or 40mm, correct? They all use the same body?
heres what i noticed. a general rule is they will go about 2mm. but because the manufactiring/machining process from keihin, none of the carbs are exactly the same. some carbs may go 2.5mm, others may only go 2mm...best way is take alittle at a time so you dont go too far
