1 - 5 of 5 Posts
Discussion Starter · #1 · (Edited)
These are not the normal Totron cubes but are considered Totron's High Lumen cubes.
All of our prices include Free Same Day Shipping to the lower 48 states.
(You must order by 3pm central. We are open Monday - Friday)
The prices reflect the 10% off when using the code Lights2015 on Offroad LED's
]$67.46 / Pair 18w 3" Cube with 6 Osram LED's. The mount swivels from bottom to back to top. (Left)
.Led Chip, Power: 6*3W Osram.Actual Power: 16.83W under 24VDC.Operating Voltage:10-30V DC.Current Draw: 12V/1.4A,24V/0.7A.Waterproof Rate:IP67.Color Temperature:6000K.Beam Pattern: Flood/90° Spot/8°.Theoretical Lumen: 1440lm.Effective Lumen: 930lm
$71.96 / Pair 18w 3" Cube Flush Mount with 6 Osram LED's. (Center)
.Led Chip, Power:6*3W Osram.Actual Power: 16.83W under 24VDC.Operating Voltage:10-30V DC.Current Draw: 12V/1.4A,24V/0.7A.Waterproof Rate:IP67.Color Temperature:6000K.Beam Pattern: Flood/90° Spot/8°.Theoretical Lumen: 1440lm.Effective Lumen: 930lm.Gasket and Template included
$69.95 / Pair 18w 6" Flush Mount Bar with 6 Osram LED's. (Right)
. LED Power: OSRAM 6*3W. Raw Lumen:1620lm. [email protected]:260lx. Operating Voltage: 10-30V DC. Waterproof rate: IP 67. Current draw:[email protected],[email protected] Color Temperature: 6000K. Material iecast aluminum housing. Lens material:pC. Mounting Bracket: Stainless Steel. Opitonal Beam: 25°. 30000 hours above life time.. Certificates: CE/ IP67/ RoHS
If you want a plug and play harness with a relay, fuse and switch then add $17.96
We also have the wireless remote for $19.76
Please pm me with your email address and if you want the harness and remote control.
I will send you a PayPal invoice which you can pay with credit card or anything attached to your PayPal account. Photograph Automotive lighting Light Product Gadget Automotive lighting Headlamp Rectangle Gadget Font Automotive lighting Automotive tire Rectangle Service Auto part
Brand new shipment is in.
We have Cree or Osram LED cubes.
Same price for either one.
The Osram are considered High Lux and the led is made in Germany.
I took 1 Cree Cube and 1 Osram Cube and stood 8 feet away from the wall and the picture is the result.
We also have Totron with Osram LED light bars (30", 40", 50" Double Row Straight and Curved) coming in this week.
Grey Rectangle Material property Font Wood
1 - 5 of 5 Posts
