planing on running on a hard pack clay track 300ft has any one ran clay what tier set up works, spikes can be ran . any one know a good tier combo , will spikes help . thanks 4 any info
i swear on ohtsu radial for that type of surface.they really hook well on alot of different tracks.they are found stock on the older 400ex's and can be had at any honda dealer for about 60 a tire.the only size they come in is 20X10X9.they are 2 ply and made of a soft compound.
QUOTE (StrokedTater244 @ Aug 21 2008, 05:49 PM) index.php?act=findpost&pid=8878i swear on ohtsu radial for that type of surface.they really hook well on alot of different tracks.they are found stock on the older 400ex's and can be had at any honda dealer for about 60 a tire.the only size they come in is 20X10X9.they are 2 ply and made of a soft compound.
if you have over 100hp Your just going to blow the otshus off. Unless you have a real short swinger ...
i used at489 with ice screws for what you describe there failry light and pretty cheap. 10 rim only for an 8-9 inch rim seems the c829 from cheng shin with screws works pretty well.
