1 - 3 of 3 Posts
Discussion Starter · #2 ·
Says for Gasoline.....
Could i still run this coolant...
Sounds like a dumb [censored] question i know but hate to drop some $$ on it and even use it.
Evan's NPG+ "WATERLESS" Super Coolant
Run Faster - Run Better - Never Overheat!
Evans NPG+ Waterless Coolant is the recommended coolant for all gasoline and diesel engines. NPG+ is a stand-alone lifetime coolant that does not freeze, or boil over. NPG+ controls detonation, cavitation, and is non-corrosive. Installing NPG+ requires the radiator, engine block and heater core to be drained completely and then filled 100% with NPG+.
NPG+ meets or exceeds both the ASTM D 1384 corrosion test and the ASTM D 3306-94 specifications.
NPG Technical Information:
* Boiling Point is 375°F @ 0 psi
* Freezing Point at -40°F
* Viscosity - 2.3cp @ 212°F
* Surface Tension - 44dyn/cm
1 - 3 of 3 Posts
