I usually have to put the bearings in the freezer or use the press. I just bought these cases used and went to install the crank bearings and one side required just a light tap with a rubber mallet and the other side just went in without and force. I put some shim stock around the bearing and tapped it in. The bearing is tight now but I'm still a little concerned.
