Ford Vs. Chevy Vs. Dodge...
As said...type of oil is hardly the problem...lack of oil, well, that's another story...
I can tell you it's important if you're purging your bike (methanol) to use a methanol compatible oil with your purge gas....
The methanol and gas will mix in the carbs from purging, and a non-meth compatible oil will gum up your carbs...been there, brake clean...solved.
If you run methanol, just make sure you run a meth compatible oil.
There was study/report somewhere that said two strokes continued to make more power with more oil all the way to 16:1....after that, the power gains were negligible..
