QUOTE (BBIII @ Nov 17 2008, 02:19 PM)
index.php?act=findpost&pid=16422If i remeber correctly that when you put a dyna on vs's the stock one, the stock timing on the dyna is 4 deg's advance so that is probally what you felt when you put it on.
I am not 100% for sure but i do remeber reading that somewhere before.
You are correct.
I've got a few of my own thoughts.
For a smaller motor, unless you're going to use it to it's potential...I don't think it's worth it.
If you have the time/means to program it on a dyno...and "tweak" it at the track...good investment.
They have other options tied into them as well (NOS activation, ignition studder...I think...)
Like Big Boy said... The option to have a NOS curve, alky curve...or other curves (1/8 mile, gas, etc.) are a benefit for sure.
If you have a much bigger motor, or a BIG single, they are a must.
For example...
Neal's big Saber would probably break your foot, or parts...without this ignition. they program it with little or NO timing for the first 1000 or 2000 RPM just so they can start the beast.....
