1 - 7 of 7 Posts
Are the arms fully adjustable. The problems lies in your castor. Most Asphault Racers set their castor to -15 degrees. It helps to keep the wheels straight and avoid shaking at high speeds.
QUOTE (AZCUSTOMQUADS @ Feb 23 2009, 09:57 PM) index.php?act=findpost&pid=31839Are the arms fully adjustable. The problems lies in your castor. Most Asphault Racers set their castor to -15 degrees. It helps to keep the wheels straight and avoid shaking at high speeds.
they are and ill set them up that way any more helpful hints ill take them thanks
Just make sure it is sitting at -15 degrees, not +15 degrees. In other words, the top of the spindle angles towards the rear as close to 15 degrees as posible. If it angles forward, its going to be a death trap!!!! Of coarse check your tow and camber as well.
QUOTE (AZCUSTOMQUADS @ Feb 24 2009, 07:33 PM) index.php?act=findpost&pid=31965Just make sure it is sitting at -15 degrees, not +15 degrees. In other words, the top of the spindle angles towards the rear as close to 15 degrees as posible. If it angles forward, its going to be a death trap!!!! Of coarse check your tow and camber as well.
man thanks alot ill get it set up asap
1 - 7 of 7 Posts
