QUOTE (Dave I. @ Mar 21 2009, 09:01 AM)
index.php?act=findpost&pid=35242Looks like the 65 LPH Mikuni flows the same as the 17GPH Aeromotive. I would rather use the Mikuni on a banshee with dual carbs as it has two outlets. Mikuni is also about 60 bucks less. Im not sure if the Mikuni is rated for meth but seems like a lot of people get away with it.
by the math yes but i run single cylinder's and the pump will out flow it i tested both with a stop watch each one twice to get a accurate reading the aromotive out flowed it buy 5-6 oz every time i see what you r saying about a shee you would need to put a tee in it and it probably would restrict flow but on a single its the boom or you could just tape a fitting 4 the extra line my pump has been going for 3 years now no probe on a shee the mikuni pump may be the best but jp is a single cylinder guy just my preference both would do him a good
