QUOTE (THEBOM @ Jan 11 2009, 11:21 PM) index.php?act=findpost&pid=25107What power ? what swing? what motor set up?
55 HP 40 ish tq, stock bore high comp. piston,cams +4 swing.......
"rotax00 's quad on the dyno sunday ill post the numbers when I get them web 109 cams, mild porting , ported intake high compression pistons 11.5.1 pro com ignition pug exhaust and a tm 45 carb 52.61h "
I'm guessing this is about Rotax00 I would think in the dirt/sand with 22's that the gearing he has on it now would work pretty good. I think its pretty hard to guess you almost need a test n tune session to set it up with what works best for the rider
QUOTE (THEBOM @ Jan 13 2009, 07:02 AM) index.php?act=findpost&pid=25399Yes, if your still running a short tire.i am running 15-40 gearing in the dirt with 22 tires i have ice picks in 20 tires last weekend i was running 660ft going through the end in fourth gear.whatz up with that?
QUOTE (rotax00 @ Jan 13 2009, 12:46 PM) index.php?act=findpost&pid=25430i am running 15-40 gearing in the dirt with 22 tires i have ice picks in 20 tires last weekend i was running 660ft going through the end in fourth gear.whatz up with that?
Its his bike ^^^^^^^ I posted for him....
