please refer to the picture below with numbered parts to help me and other understand what you are talking about. I will do the same because im not sure of the exact names of certain parts. Thanks. The picture is all parts apart but are layed out how i assembled them in order.
http://rc.superdave2u.com/MyBanshee/slings...e5%205-7-09.JPG
Ok guys, ill try to make it short and sweet. I welded my ball to the rod a couple weeks ago. Stupid me goes put the same damage ball and pushrod back in there but i added a pancake bearing. Fast forward to a few days and the push rod gets welded to the clutch actuator. So i had to split the cases and get it out.
Fast forward to about an hour ago. I seen why my pancake bearing didnt work. It's suppose to spin freely and it doesnt spin at all. It has a very strong bind on it when assembled. When i tighten the nut(5), the whole assembly doesnt spin at all. It creates a bind. I understand maybe i can not tighten it down as much but how would i be able to adjust it right and keep it from backing out?
These are pictures of it assembled.
http://rc.superdave2u.com/MyBanshee/slings...e1%205-7-09.JPG
http://rc.superdave2u.com/MyBanshee/slings...e2%205-7-09.JPG
I got the cheap pancake bearing with just the pancake bearing and the washer(3) . I had it installed w/o the washer(3). But now i see it doesnt make a difference as far as i could tell. I know cascade makes a set up for $45ish but what i have should work. The only reason that it wouldnt is because maybe i have a lockup.
Can someone tell me what i am doing wrong? I can put it all back together like this but w/o that pancake bearing doing it's job, i will be back to welded things together. I do have an override so this is something i need.
On a side note, it's a pain in the butt to have to keep flipping the bike on it's side. Damn slingshot works like a charm but i never thought about having to keep flipping it on it's side everytime i wanna take the plate off.
