McMaster has polyurethane fuel lines with up to a .125 thick wall
Part Number: 5108K55
1-99 Ft. $2.15 per Ft.
100 or more $1.58 per Ft.
Type
Abrasion-Resistant Clear Polyurethane Tubing
Material
Ester-Based Polyurethane
Shape
Single Line
Outside Dia.
9/16" (.5625")
Inside Dia.
5/16" (.3125")
Wall Thickness
1/8" (.125")
Available Lengths
5, 10, 25, 50, and 100 feet
Reinforcement
Unreinforced
Color
Clear
Maximum Pressure
100 psi @ 73º F
Operating Temperature Range
-70º to +175º F
Bend Radius
3-3/8" (3.375")
Durometer
85A (Firm)
Tensile Strength
5,000 psi
For Use With
Air, Bleach, Food
Sterilize With
Gas
Specifications Met
United States Food and Drug Administration (FDA)
FDA Specification
CFR21 177.2600
Compatible Fittings
Barbed
WARNING
Tubing will crack if used with water.
