QUOTE (2gofast @ Jul 17 2008, 10:58 AM)
index.php?act=findpost&pid=5652The Cheetah DM's use the CR500 bolt pattern, but the carb comes straight out from the cylinder, (in the side-to-side direction), so be sure you don't have a shock clearance issue.
You can use the stock boot as long as you use a sharp rotory file and cut the inside of the boot to make it thinner ,and use a 44 lectrron. I dont think youll get a 48 on a cr500 my 44 is right on the shock spring, so I put a shock sock on it to help with any movement, I also had a custome built billit intake made because the stock airbox boot wont fit .
