QUOTE (bigdaddy69 @ Feb 8 2009, 06:03 PM)
index.php?act=findpost&pid=29625I will be putting my motor together next weekend Its going to be stock cyl 4 mil drag port 1-5 override, slingshot lockup, stock ported reeds SB CPI OOF pipes. Going to be running 35 PWK's on alky. Will be my first experience with alky so I just want a base line where to start. As of now they have 155 mains 40 pilots and CEL needel. They of course have powerjets. My elevation is around 3000-3200 feet temps are in the 40-70 range right now.
Down the road, bigger carbs for alky would be my choice, to be honest. We run 39 on stock cylinder/stock stroke around here.
I'd say start with a 55 pilot, .122 dump and .122 main, power jet all the way out, and EGJ or EGK needle.
At your elevation, that should be safely rich....which is the best way to start out on a methanol motor.
I have to say this since you mentioned gas jets.
You know you have to drill out the dump tube (also called the emulsion tube) and main jet with a drill bit, right?
On a Keihin, once you drill the dump tube, you can not go back. The dump tube on a Keihin is NOT replaceable...so, careful on going too big.
