1 - 17 of 17 Posts
Started out as a stock Dunlop tire. Im too cheap to just buy a set. Figured I've give this a shot....if it works, good, if not Ive only lost a couple hours time. I was suprised that it dropped more weight then I though. One scale says it lost 3 pounts the other says 4 pounds.
FINALLY got around to finishing this...almost...getting them mounted on wheels tomorrow. Figured no better place to test them then Little Sahara.
Showing one have buffed, other half just snipped.
I made a messs...
Discussion Starter · #4 ·
Its pretty even. Basically just cut the knobbies, and grinded the knobbies down level with the carcass then just buffed the whole carcass to give it a uniformed look.
It was basically just rubber dust so it whipped right off.
What did you use to snip the lugs off? And what grit paper did you use on the grinder?
QUOTE (KX500Zuki @ May 12 2009, 08:05 PM) index.php?act=findpost&pid=42339What did you use to snip the lugs off? And what grit paper did you use on the grinder?
i have the same questions as him^ i have an old set of worn out tires that i would love to try this on. look really good. i had thought about trying this several times just never did cause i didnt thin it would work good. but yours look good to me so i wanna go for it.
I honestly have no clue what grit the disk are. To be honest everything I used was completely unconventional and not intended for this. To cut the knobbies I used a set of hoof snips that we use on cattle like this....
And you can see the grinder and disk I used on the ground in this pic. The grinder is just a regular Makita.
And the disk are metal disk used to trim hooves on cattle. The medium grit.
link to disk
i tryed this after he did and i barely have any done. but i tried using a grinder with a metal disk on it and all it does is melt the rubber. i am going to try som tougher grit sand paper next and see what it does.
QUOTE (jtraptor660 @ May 14 2009, 09:20 AM) index.php?act=findpost&pid=42542i tryed this after he did and i barely have any done. but i tried using a grinder with a metal disk on it and all it does is melt the rubber. i am going to try som tougher grit sand paper next and see what it does.
What grit did you try? I am thinking about trying this, maybe with 36 grit?
Discussion Starter · #13 ·
QUOTE (jtraptor660 @ May 14 2009, 11:20 AM) index.php?act=findpost&pid=42542i tryed this after he did and i barely have any done. but i tried using a grinder with a metal disk on it and all it does is melt the rubber. i am going to try som tougher grit sand paper next and see what it does.
Maybe it's a different compound of rubber? When I did it I had a whole tire buffed in about 45 minutes at most.
to make it easier to cut the nobbies off- find a dirt tracker (race cars) and see if they have a tire groover- basicly it is a hot iron that melts the nobs off, then you would have easier time buffing the wheels-
But this looks like to much work for me-----LOL
1 - 17 of 17 Posts
