Ok, i got this raptor from Jose T, traded my banshee for it! Its a Craycraft 727 with 106mm bore, 14 to 1 compression, cryo treated gears, carillo rod, craycraft cams, valves and springs, 39 fcr's on alky and dyna ignition. It's got a metal tech +10 swinger, JJ&A gun drilled axle, marvin shaws up front, strut in the back. Motor is real strong it has run a 4.7 with a 250lb rider. What im doing is rebuilding everything but the motor, i have fireball racing drag a-arms, billit tie rods, polished side cases, barker oof drag pipes, billit thumb throttle, bars, 10x4 polished fronts with 10x4 ashpalt or dirt tires and alot more billit pieces! Not sure what paddle im gonna run yet! Right now its stripped down, just the motor in it, im having the frame, sub-frame and front spindles powder coated illusion green(it's like a extra metal flake emerald green) and the swing arm, a-arms, steering stem, oil tank, and wheels are gonna be black powder! Here's the pics of it when i first brought it home, and i will get some up of it now, and some of the parts! So any suggestions, pointers or have any parts that might make it better, please let me know! Thank You!
