Lowbuck, do a google search about lectron tuning. You will find the reading very useful. A lectron only has 3 basic adjustments, the idle, the needle, and the powerjet (or powerjets) I always recommend a double powerjet setup, unless you have a packard or Dave Moore style. On a stock bowl I also like to remove one float for more fuel capacity. Once you get the carb on the bike, there is no need to ever pull the bowl unless there is a float valve or leak problem. They are simple yet very effective carbs.
