I'm thinking it might be the water pump gear or the strait cut gears making the noise I'm think that its the water pump gear the most because when I took it off the c clip has wear and is really lose and the washer that sets behind the clip has wear from it spinning in there plus the gears teeth look to be worn on the crank gear side and some of the teeth have very little chips in them but all of the teeth look arounded off on the side of the crank gear I think I might have got a little bit crazy with the sealer to make the key way stop leeking what do you guys think.
