QUOTE (Kawiking @ Mar 3 2009, 06:12 PM)
index.php?act=findpost&pid=33028what size motor was in that frame ?
how thick are those bars comin down from the sub frame ?
it had a dune ported 350 in it before.... but he never got to finish it.
1/2" might cut um out and put 3/4" not sure yet...
QUOTE (AZCUSTOMQUADS @ Mar 3 2009, 06:50 PM)
index.php?act=findpost&pid=33030Right on JT!!! Like Bobby was saying, if you are going to dune that then definitely add some bracing. Add some bracing for the stem hoop, some uprights from the lower to upper main rails, gusset the rear shock mount, and I would suggest running the rear linkage like it was setup for. That will help eliminate some stress as well along with keeping the shock angle better. I would try to figure out a way to brace the single tubes for the front end.....that looks a little scary for a dune bike.
thank ya for the ideas! Do you happen to have any ideas on how to brace the front bars? this will be used mostly at the track with struts all around.... but I have been known to hit the dune drag stip now and then so I will sacrifice alittle weight for safety!
