01 banshee dune port 4 mill crank .. stock ig. every 5 to 6 kicks will spark one time ? check trigger gap and stator , on off switch and plugs everything so far good ... ran fine untill washed and set for 3 weeks ? no wont run wtf
Pull your stator cover off, there may be water behind it. If so, there could also be rust, causing a poor connection between the flywheel and pickup coil.
