QUOTE (phatboyz @ May 22 2008, 07:40 PM) index.php?act=findpost&pid=834yes they can on certain app if close enough cause an intermitent (spell) spark
would you be able to shield it with like a peice of rubber or something? mines about 6-8 inches apart nology coil is in stock location and cdi is mounted on one of those gb racing mounts
QUOTE (banshee332 @ May 22 2008, 07:53 PM) index.php?act=findpost&pid=837would you be able to shield it with like a peice of rubber or something? mines about 6-8 inches apart nology coil is in stock location and cdi is mounted on one of those gb racing mounts
Im running b8egv plugs with a 4mill triple cylinders wha plugs should I run.
QUOTE (banshee332 @ May 23 2008, 12:11 AM) index.php?act=findpost&pid=842Im running b8egv plugs with a 4mill triple cylinders wha plugs should I run.
BR8ES or B8ES. I've never been a fan of the smaller firing tip plugs. That nology is potent, the run of the mil ES series worked fine for me on gas or alky!
I would just run it and see if it does it or not and if your running alky with good timing your running the same plug I and many others run...Its a good plug and Id stick with it.
QUOTE (phatboyz @ May 23 2008, 10:49 AM) index.php?act=findpost&pid=890I would just run it and see if it does it or not and if your running alky with good timing your running the same plug I and many others run...Its a good plug and Id stick with it.
Shannon..I'm pretty sure this is a gas bike...FYI.
QUOTE (banshee332 @ May 22 2008, 08:53 PM) index.php?act=findpost&pid=837would you be able to shield it with like a peice of rubber or something? mines about 6-8 inches apart nology coil is in stock location and cdi is mounted on one of those gb racing mounts
If you have an EMF or ground feedback problem, wrapping the CDI in tanalum foils may help get rid of the interference.
1 - 9 of 9 Posts
