1 - 13 of 13 Posts
You dont want to go lower on the rear shock Jesse. The Bottom frame rails look to be at a pretty good stance. The Subframe is at a pretty extreme angle, much higher than stock geometry. Try holding the bolt on subrame up to it to see if it could adapt to that chassis. It might work out great!
Ya Jesse I thought it was crazy high in the rear but it worked for Rico , he said it kept him pushed forward by the tank. Looks good.
1 - 13 of 13 Posts
