Got the straight axle all built up, and also found the handle bars I am going to run with. Also got everything shaved ang grinded down that I don't need. Here are few pics of the progress.
that front end Idea has death wrote all over it man... havent you ever seen drag shee's with -1 and -2 a-arms? they do that for a reason. Your front end needs to be pretty close to the same width as your rear end. any Idea's on a motor?
P.S. Direct drive makes a lockup but you'll have to have someone modify your clutch cover to make it fit... RDZ also has a lockup
yeh man I dont know about that front end. If it where me I would want it to be a little more narrower, Plus I think that the spindils should have a certain amount of degree to them
That's a one of a kind front settup goodluck with it, the plastics look sick. Also would you mind resizing your sig picture my scroll down finger is killing me.
So what's going on with the cylinder, what are you throwing in there? Portwork, stroker, carb, etc??
You even have room to weld a nose pices and move that front end fwd, how big on the swingarm? Sick cosmetics for sure + the bars!
