QUOTE (banshee217 @ Sep 22 2008, 09:20 AM)
index.php?act=findpost&pid=11271Does anyone have a good reason to run reed spacers other than spacing the carb from the clutch actuator? I've read both sides saying to run them and also not too. It seems that they would only increase crankcase volume if installed between the reeds and cylinder which I believe would give you less power or if installed between the reed and intake would only lengthen the intake tract and essentially do the same in reducing power unless you put in some serious stuffers.
Can anyone elaborate on this?
Many years ago. I ran a reed spacer on my 250R. I tried it between the cylinder and the reeds. It seemed to make more low end power installed there. I tried it between the reeds and intake boot. It seemed to make a broader mid range and shift the power a little more toward the top end.
These days I have a banshee. I run reed spacers on it too. Installed between the reeds and the intakes. But, I have nitrous foggers installed in them.
I think your results would be similar no matter what bike you ran them on. It just depends on what its set-up for, and how you like the power delivery. I don't think you get a horsepower gain from them. They just effect the way the power comes on. But, of course this is jmo. LOL
