1 - 8 of 8 Posts
66 bore 61 stroke
Stock carbs and air box
Shearer 2 to 1 pipe
Custom cylinder head
Port work on OEM cylinders
V-Force reeds
This is the only Banshee pipe that has power under 5000 rpm
Its killer set up for dunes and trails
Did you try any toomy t-5's or snipers on it
This project was totally focused on roll on power. I worked on power under 5000 RPM to help a banshee trail rider get the acceleration through the corners and over the obstacles that they they would have to tackle on the trails. It also would be a killer dune set up with carbs larger then stock, the power would increase well in to the 70s with out sacrificing much power loss below 3000 rpm
The Sniper pipes and T5s do not come on below 5K, so no need to try it
Thanks
It may be kind of overlooked. This is a 2 INTO 1 PIPE.
I dont think topend or peak HP was Matt Shearer's focus with this pipe.
Its designed for lowend and roll on power making a bike fun and easy to ride from down low and still be able to rev out.
Looks like it would be a fun motor on the dunes and trails.
1 - 8 of 8 Posts
