What's everyones secret tip to get it tightened? I've seen people wedge a rag in the gears and then tighten it are there any other ways? Does everybody use a impact as well?
Easiest way to do it is to just put the clutches in it and press against them while hitting it with an impact. The pressure on the plates keeps the inner hub from moving.
QUOTE (KaosBanshee44 @ Oct 1 2008, 07:35 AM) index.php?act=findpost&pid=12139That's what i ended up doin was just hitting it with a impact. Does it have to be exactly 66ft pounds?
no, i never torque mine. i just tighten it up and bend the tab over it
QUOTE (KaosBanshee44 @ Oct 2 2008, 01:17 PM) index.php?act=findpost&pid=12252I ended up just using a impact but used it carefully then tabed over the lock washer. It's not going nowhere
We use 4 small bolts or rivets to mate an old clutch fiber and steel together to hold the inner hub and basket.
With an impact it doesn't take much to reach 66ft lbs, and lock the tab.
QUOTE (portworks @ Dec 1 2008, 07:12 PM) index.php?act=findpost&pid=17942We use 4 small bolts or rivets to mate an old clutch fiber and steel together to hold the inner hub and basket.
you could always use the vise grips they sell for doing that job
QUOTE (ClimbAnyHill @ Oct 2 2008, 02:16 PM) index.php?act=findpost&pid=12244Me too, give it a couple pumps and bend the washer tab over it..
I use a penny right between the gears, it's soft and soaks up the gear bite!
I AGREE TOTALLY WID THE PENNY TRICK, WORX EVERY TIME
QUOTE (stroked310r @ Dec 14 2008, 05:14 PM) index.php?act=findpost&pid=20668wait jus a minute now, i didnt say nutn bout throwing a penny away, bent or not bent itll still spend! LOL
QUOTE (vwpartsman @ Feb 27 2009, 03:25 PM) index.php?act=findpost&pid=32467I got them on sale today only at $.05 each!!! Get them before there gone!!!bargain!!!lol
QUOTE (little cubbie @ Dec 13 2008, 07:00 AM) index.php?act=findpost&pid=20472motion pro makes a tool for about $30 that works like a set of vice grips with bent ends that clamp on your inner clutch hub that WORKS GREAT.
yup. works great. i bought one couple years ago, seems like it was only $20 back then though. works on clutch, front sprocket, flywheel
