1 - 10 of 10 Posts
okay. some people already now what i have. but here it is again. stock 350, triple drag ported, cpi oof, 35mm airstykers, stock welded crank, advanced timing, dyna ingnition, cool head, 17cc domes, lock up, 2-5 overide, +8swinger and 20x10x8 12 paddles extremes, on race gas. 15/46 gearing i think. my ? is will i have any issues pulling a 2nd gear start in the sand and will i be okay in gearing though the end of a 300ft drag with the 20" tires.
QUOTE (jtraptor660 @ Nov 26 2008, 10:26 AM) index.php?act=findpost&pid=17516okay. some people already now what i have. but here it is again. stock 350, triple drag ported, cpi oof, 35mm airstykers, stock welded crank, advanced timing, dyna ingnition, cool head, 17cc domes, lock up, 2-5 overide, +8swinger and 20x10x8 12 paddles extremes, on race gas. 15/46 gearing i think. my ? is will i have any issues pulling a 2nd gear start in the sand and will i be okay in gearing though the end of a 300ft drag with the 20" tires. You need to re gear it man! With a 2-5 in 300' run a 13-44 or 14-44 combo!
You are running 20" 12 pdls?
If that is the case you should have no problems launching in 2nd with them.
With my 350 on alky, i am running a 14-42 gearing with a 22" 12 pdl extreme and launching in 2nd.
QUOTE (BBIII @ Nov 26 2008, 10:03 AM) index.php?act=findpost&pid=17525You are running 20" 12 pdls?
is there a huge difference from the 13 to the 14 if i run a 44 in the rear.
1 - 10 of 10 Posts
