QUOTE (94sheeMAN @ Nov 21 2008, 05:39 AM)
index.php?act=findpost&pid=16983well i got ahold of him and he suggested atf dextron 3 or higher or mercron 4 or higher. heres a question.... why use ATF instead of an atv tranny oil?
The clutching system in an ATV is identical to the clutching in an automatic transmission in an automobile. It is this reason that you can run ATF successfully.
I try to stay away from ATF when I can. In my experience it creates more heat on the clutches, makes them slip more, and significantly increases "creep" when staging. I now use Motul and it has eliminated creeping and my clutches last longer.
